Cobra 42 21T backup
Results 1 to 9 of 9
Thread: Cobra 42 21T backup
    Member cooperjm's Avatar
    Sep 2009
    Default Cobra 42 21T backup
    Does anyone have the procedure to do a full backup to include the ladder for the 21T controller?
    I tried doing a backup to the pcmcia card in the controller and electrical cabinet. It did not recognize that there was a card there.
    I have been able to back up what I can with the rs232 cable. I just can't seem to figure out how to get the ladder out of it.
    Sent from my SM-G955U using Tapatalk
    May 2016
    United Kingdom
    Default Re: Cobra 42 21T backup
    What size is the PCMIA Card ?
    Sep 2009
    It looks like one of these.
    Member Michael82's Avatar
    Nov 2007
    Quote Originally Posted by cooperjm View Post
    If I were you and you cant get it backed up take pictures of each page with your cell phone, You would have to go thru it manually and make the necessary changes by hand but at least you would have it
    Sep 2009
    I have taken pictures of the various screens that will not punch out. That method will not help with the ladder though.
    Nov 2007
    I must have misunderstood what you are trying to do with the ladder ? The ladder for a cnc control is to show/explain where certain components are located and or if they are being used at a certain time . What is it that you are trying to do ? reload it into the system after a memory reset?
  7. #7
    May 2016
    United Kingdom
    Quote Originally Posted by Michael82 View Post
    If you need a pmc ladder back up you will need an sram card
    The memory card your using is a flash card
    Whereabouts are you maybe someone on here is local to you
    If your doing a memory clear the old file should be ok
  8. #8
    Sep 2009
    So how do you get the controller to back up to the SRam card?
  9. #9
    May 2016
    United Kingdom
    You put the SRAM card in the same place as you put the PCMIA card (on the I/O Board )
    Then power up holding the two right hand soft keys under the screen
Cobra 42 21T backup
Cobra 42 21T backup
