Cobra 42 Fusion 360 post
Results 1 to 6 of 6
Thread: Cobra 42 Fusion 360 post
    Member cooperjm's Avatar
    Sep 2009
    Default Cobra 42 Fusion 360 post
    Is anyone using Fusion 360 to program their Hardinge lathe? If so which post are you using? Have you edited it to make it better?
    Sent from my SM-G955U using Tapatalk
    Aug 2008
    Default Re: Cobra 42 Fusion 360 post
    Quote Originally Posted by cooperjm View Post
    did you ever figure this out?
    Sep 2009
    Yes I have a post that I'm using with the lathe it works okay. It does not do the drilling Cycles. That is just something that I've lived with. Have not spent the time to fix it
    Aug 2008
    I'm hoping to be the new owner of a Cobra 42 very shortly and just trying to get some information lined up.
    For the drilling cycles, does the cobra 42 accept a drilling cycle? Or is it that the post just needs to be formatted to output the code how the cobra needs to see it?
    Sent from my SM-T727V using Tapatalk
    Sep 2009
    The post needs to be reformatted to work with the canned cycle for that controller. There is also a deep drilling cycle that is a macro program of the controller that works really well.
    I have a lot of extra tool holders for mine. If you need some get in contact with me and I'll see what I can sell.
    Also if you're going to do any tapping you we'll need the self-releasing tap holder.
    Aug 2008
    Cool! That's awesome, once i pick it up and get it setup I'll take a look at the post and see about coding everything for the post to get it working. Any other info on the machine you could share that may get me started in the right direction or things to check would be greatly appreciated!
    Chris
