Need Help! Hardinge GS51 Lathe, cutting wrench flats
Results 1 to 2 of 2
Thread: Hardinge GS51 Lathe, cutting wrench flats
    Default Hardinge GS51 Lathe, cutting wrench flats
    I'm running a Hardinge GS51 Lathe, Fanuc Series oi-TD controls. I want to cut wrench flats in the Sub Spindle. I have a running program that I'm using to cut flats in the Main Spindle. I didn't write it. When I try to run the same program in the Sub, It will only cut one flat, not four. Here's a copy of the program.
    N2(SIDE CUTTING MILL,MAIN SPINDLE)
    M98P1
    G50S2000
    G98(IPM)
    M66
    M23(CS AXIS)
    T1111(3" DIAM SIDE CUTTER)
    S1800M52P3
    G0X5.00Z-4.870C0
    G112
    G01C-1.685F50.0
    X-3.370F15.0
    C1.685
    X3.370
    C-1.685
    G113
    M24
    G00X5.00
    M98P1
    M55
    M64
    #500=#500+1
    M30
    Thanks, Dean
    Mar 2017
    Default Re: Hardinge GS51 Lathe, cutting wrench flats
    It is polar. are you really using a 3.0 dia cutter?
    What is the distance across flats you are wanting?
    The Z depth in the program is negative. I would expect it to be positive on the sub, unless it works different than I have seen before.
    how many boxes of #2156 will you give me for helping you?
