- Need Help!- Hardinge HNC with Fanuc 21-T controller will not power display
Re: Hardinge HNC with Fanuc 21-T controller will not power display
What is your power source?
240 3PH?
208 3PH
Or phase converter?
What voltage?
What voltage was the previous owner running?
These are all important starting points.
The machine runs on 208 3 phase, coming from a phase converter to the same 208 transformer that the previous owner used.
Machine is listed as a 2.5 hp motor, purchased a 5hp phase converter. The lathe is directly connected to & powered by the controller.
I've had the machine operational twice since bringing it home & powering it up. Now the display is not operational.
The weird thing is that I have power to & thru the controller enclosure. The Fanuc drivers light up, and a fan on the lathe turns on. The display for whatever reason is not receiving power.
I've looked for any type of fuse, loose wires, bad switches, with no luck.
I figured this is (or was) a common controller & someone may have had a similar issue and was able to resolve it. It's probably just something small & goofy that I'm overlooking.
So your problem is you get nothing on the CRT/Monitor, correct?
In this state, can you jog the machine around?
Is everything else working but the CRT/Monitor?
One other question. Was this machine previously running on real power company 3PH?Some machines do not like those phase converters. I know you said you had it running a few times.
But this sounds to me like the machine is baulking at your manufactured 3rd leg of power.
Your power source may need tweeking. And you may have fried something in this process.
Check the output of your power supply. From memory you need at least 23.2 Volts DC to power up the CRT.
- You may not post replies
- You may not edit your posts
Forum Rules
