Hi, I have a Hardinge Conquest T51 with fanuc 18T. I don't have its maintenance manual.My machine getting alarm 1020 Chuck open. Can you please help me in this regard as you have same machine running. Thanks
I've been working towards getting this lathe up and running in our shop for the last few days and so far everything has gone well, but now I'm really stuck. It turns out a previous employee decided to take it upon himself to disassemble the lube system in an effort to diagnose and fix the "Lube System Failure" error. This puts me in a bad situation because now I have no idea how the lube system was originally wired. Would anybody that has this machine or a similar model hardinge with the bijur oil system be able to take a picture of the terminal block inside the auto oiler housing? This would at least give me a solid base line to begin troubleshooting the problem.
Thanks in advance,
Cameron
Sent from my SM-N900V using Tapatalk
- Need Help!- 1016 Lube System Fault on Hardinge Cobra 51 w/ Fanuc 21i-T control.
- hardinge conquest 51
- Need Help!- Hardinge conquest 42
- Need Help!- Hardinge Conquest 42
Cameron, I will send you wiring picture tomorrow morning for sure.
Usually you get the "chuck open" message when you try to cycle start the machine with the chuck open, which you can't do.
Probably got the machine set for internal or the hoses round the wrong way
Manuals available if required
Hi, Can you please send me wiring diagram picture @ rupeshjn@gmail.com?
