Did you ever find out?
I just got an HC with the AT threading attachment and mine doesn't have that either.
Do you have a PDF of the threading attachment docs? Could you please share?
Hello,
I bought this machine which had the threading attachment but is missing this arm(the book refers to it as the support bracket which rides on a block bolted on the turrett.) The manual says it's used when you cut coarse threads and/or harder material(i.e., stainless).
Does anyone know where I might find the arm?
Thanks in advance
