Problem Conquest 42 / Fanuc 0-TC / Parameters needed
Results 1 to 12 of 12
Thread: Conquest 42 / Fanuc 0-TC / Parameters needed
    Jul 2012
    Default Conquest 42 / Fanuc 0-TC / Parameters needed
    Hi there,
    I have this Conquest 42 with Fanuc 0-TC, serial number is CS-1337-C. It lost parameters when I changed the keypad that was falling apart, and the new one was too tight and obviously kept a couple buttons pushed in when I turned it on...
    I contacted Hardinge USA and the service guy sent me 3 files which are '900 stsndard cPAR~1.txt', 'CSGENERAL.TXT.dat' and 'CSMACRO.txt'. He told me they were generic files for that Conquest series and not specific to my machine. Needless to say, it didn't helped me much. Those '900 stsndard cPAR~1.txt' parameters bring alarm 409 and 1008 with the load meter maxing out and AL-34 in the back board. I've narrowed the P917 being the cause of it, and if I leave it as in 'CSGENERAL.TXT.dat', I don't get those alarms. Instead, I get the 1004 alarm even though the brake does work. I can do the zero return, but it doesn't get out of the ZRN state. It doesn't go to 'auto' and ready.
    Would someone with comparable machine be able to send me his parameters?
    -It has 10’’x14’’ travel, 10 stations turret with 5 live tools, tailstock, tool probe.
    -It doesn’t have sub-spindle, part catcher, barfeeder, air blast, hi pressure coolant.
    -Not sure if C is full or indexer, we’ve only used it as indexer. The first guy to set it up for us said the backup batteries were dead and parameters gone. I don’t know what he did to make it work. We’ve only been able to use the C as indexer since then though.
    Any help would be appreciated. Thank you.
    Jul 2007
    Default Re: Conquest 42 / Fanuc 0-TC / Parameters needed
    Did you get the 300 series diagnostic bits to tell the brain what kind of machine you have - 10/12 station turret, live tooling/not, tailstock/subspindle, like that?
    Regards,
    Newc
    Dec 2003
    PM sent.
    Jul 2012
    Quote Originally Posted by newc View Post
    Regards,
    Newc
    No, that is not something I got. What Hardinge sent me was the P900's for 0TC, and the P0-P900 + P8000 for generic CS.
    If someone has diagnostic parameters, I'd like to take a look a those. And if for 10 station turret / Live tooling / tailstock / tool setter touch probe, that'd be even better. But I'll take a look at anything.
    Thanx
    Jul 2012
    Or would someone have the Fanuc 0-T parameters manual? That could help me I guess.
    Dec 2003
    Emailed over.
    Jul 2012
    You the man. That's 0-TD, but I guess it's worth looking into an try a couple things, see how far off (or not) those are from 0-TC. Thank you.
    Quote Originally Posted by Al_The_Man View Post
    Emailed over.
    If anyone has 0-TC programming manual, I'm still interested.
  8. #8
    Member sting007's Avatar
    Feb 2015
    Quote Originally Posted by MorueM View Post
    Did you solved your problem, I am facing same problem
    Would you please send a copy of the parameters?
    Sting
  9. #9
    daluchman's Avatar
    Aug 2018
    Emailed over.
    Are you able to email me over the same parameters for the Harding conquest T42?
    I lost them all and I need to get some jobs out like yesterday. I am dead in the water. If at all possible I am not quite sure how to load them back into machine so I would greatly appreciate any knowledge or information you can give me
    Thank you in advance
  10. #10
    daluchman's Avatar
    Aug 2018
  11. #11
    Feb 2012
    Hello AL , we have a Conquest 42 Fanuc 0T and the batteries died we lost all parameters..
    Would you be able to email me the list of nc parameters and the pc dgn 300-900..
    I have lots of machine parameters on file but nothing for this machine..Thank you
    in advance for your expertise..Tony email tnysoliz@yahoo.com
    I will reciprocate with any params you may need that i have...ie mori ikegai hyundia seiki..etc
  12. #12
    Sep 2014
    FANUC 0-TC programming manual. I have got.
