Hardinge chnc1 parts for sale
Results 1 to 15 of 15
Thread: Hardinge chnc1 parts for sale
    Oct 2006
    CANADA
    Default Hardinge chnc1 parts for sale
    I have hardinge chnc1 parts for sale . All the electrical parts and some of the air driven parts are getting changed out. Leave a post with email and as I get a chance I will get in touch with you. Just looking to get enough for new aftermarket electrical and drives
    Nov 2011
    Default Re: Hardinge chnc1 parts for sale
    looking for CHNC II 16c collet closer parts / also i have a CHNC for parts
    ed
    Masroor1's Avatar
    Dec 2013
    Gujranwala
    Dear I need index stop mechanism control, in this mechanism I need one pneumatic control 4 way valve, R481-12 12 volt Dc valve made by CLIPPARD and one valve made by MEAD Chicago HT-100P, Please contact me at masroor6350@gmail.com. Tanks Masroor Anwar
    May 2009
    would you have a plate to cover the micro switches on a hardinge chnc 1 i could send you a picture of what i need
    Attached Thumbnails Attached Thumbnails Hardinge chnc1 parts for sale-0113201437_hdr-jpg
    Nov 2011
    Clamdigger,
    No but still have other parts ! Also have parts for a CHNC II with 810T control all boards ext.
    Thanks Ed
    Nov 2011
    Clam digger,
    Found one !!! Came off a CHNC I 810T control . Got plate with switches and cover . ed.murch@mamcomolding.com
    Ed
  7. #7
    Member moonman5's Avatar
    Aug 2012
    UK
    Have you still got the Interface board?
    Thanks, Allen.
  8. #8
    Nov 2011
  9. #9
    Nov 2011
    Allen,
    Yes ! Want to make sure they match !
    Ed
  10. #10
    May 2009
    Hardinge chnc1 parts for sale-chnc1-lubricator-02-jpg hardinge chnc1 i am looking to buy L in the diagram
  11. #11
    Nov 2011
    Looking for a X axis ac motor for a CHNC I
    Wiring diagram A13B-0139-8540
    Control GEF OTB
    CN-3085-T
    Do have spare DC motors for CHNC II
  12. #12
    Nov 2011
    CHNC I can't read the tag on the X axis AC fanuc motor to replace ! Can someone help please !
    Ed
  13. #13
    Sep 2010
    Quote Originally Posted by Edwin Murch View Post
    ed
    Looking for the sheet metal base for early chnc
  14. #14
    Aug 2012
    UK
    Hi
    Do you still need the I.d tags for the servo drives?, I removed mine for both
    X and Y motors so I could get info for a retrofit,
    And can sen pictures if you wish,
    Allen
  15. #15
    Jan 2009
    Allen,
    Ed
    Don’t know if you found one, but unless you want to keep it all stock, I replaced that whole air assembly from Amazon for like $38. Nanpu I think is name. You loose your low-level alarm switch but what the hell. Actually I’m writing because with the stocker I had a problem with water getting past the drier cup and accumulated in the mist feed cup. Problem is, it draws up a tube from the bottom so ya end up feeding water, not oil. Not good.
  16. #16
    Feb 2010
    Looking for the turret position switch/encoder for a CHNC II under the cover on the cross slide. Mine is encased in a resin body with 6 wires.
