Try taking the lubricator reservoir off and clean the intake screen. I had the same problem and that solved it.
Halp!
I have a Hardinge Cobra 51 with a Fanuc 21i-T control. I am currently being plagued with
"1016 Lube System Fault"
every time it cycles from the way lube pump/reservoir. I have been using TONNA S2 MX 68 for way lube for the past year, this has only been a problem in the last couple of months.
Any help/input will be appreciated.
Well, I fought this problem on and off for a while, finally called a tech in. Took him about ten minutes to diagnose that my way lube pressure switch had gone bad. Ordered a new one, installed it, and the machine now runs trouble-free.
