Drill holes at an angle in superalloy....and deep too
Results 1 to 4 of 4
Thread: Drill holes at an angle in superalloy....and deep too
    Jul 2007
    US of A
    Default Drill holes at an angle in superalloy....and deep too
    We have a upcoming project in A286 iron base superalloy HRC 32 flat stock
    (30) .276" holes drilled 1.25" deep at a 50 deg angle to cross holes
    and
    (42) .197" holes drilled 1.05 deep at a 60deg angle to cross holes
    Should I pre drill with a short drill first or go in with an endmill and make a flat
    Also we are considering drilling deep holes in this part
    (2) .313dia 17.23 deep
    (4) .375dia 17.3 deep
    Any advice on sfm and chipload on carbide drills would be appreciated, along with any other things to look out for.
    I'm just a butcher masquerading as a machinist
    Member mactec54's Avatar
    Jan 2005
    Default Re: Drill holes at an angle in superalloy....and deep too
    Quote Originally Posted by gogego View Post
    and
    You have to make a flat the dia of the drill you will be using, spot drill then drill your hole
    For your deep holes you will have to Gun drill them
    Mactec54
    Jul 2007
    US of A
    How about feeds and speeds for drilling and milling
    I am seeing about 30 sfm and .002"ap for tooling around 3/8" or a little smaller?
    Also seems that hss steel is used more often than carbide.
    Jan 2005
    I think you will find something close enough in this PDF
    Attached Thumbnails Attached Thumbnails Drill holes at an angle in superalloy....and deep too-guidetomachining2002-pdf
    Mactec54
