I have seen some in "candy jars" at Home Depot. Check them out, perhaps you can get supplier info from the jars.
bob
I'm not sure if this is the right forum for this, but my company is looking to buy larger quantities of 1/4" hex insert bits, the 1" long type, commonly used in screwdrivers. A whole mix of different head styles- Phillips, Pozi, hex, slotted, etc.
Typically it looks like you need to be buying several thousand bits before you go directly to most manufacturers. We're looking at buying a couple thousand with each order. Does anybody know of a good source for these, where you can get wholesale type discounts?
And no- we're not planning on machining these ourselves!
p.s. any suggestions for other forums for info would be appreciated too
bob
Ingear,
Blatts Bargains on e-Bay sells them cheaper than anyone.
http://tinyurl.com/39coh6j
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
You might try contacting Apex and find a rep/distributor.
http://www.coopertools.com/catalog_p...1=10&catlan=EN
