VF2 Serial port problems
Results 1 to 2 of 2
Thread: VF2 Serial port problems
    Dec 2005
    Default VF2 Serial port problems
    I just purchased a new to me 2000 Haas VF2. The top serial port is physically missing. I initially tried to upload programs through the second serial port but had no luck communicating and then come to find out Haas says only the top serial port is for file transfer. Inside the cabinet I can see a dangling ribbon cable (see pictures) and I am assuming it is supposed to go to the missing serial port PCB. Hoping to just buy a new serial PCB from Haas and plug it into that cable but the label on the cable says "RS232 video". Any insight to this problem would be greatly appreciated.
    Thanks!
    Attached Thumbnails Attached Thumbnails VF2 Serial port problems-img_3998-jpg   VF2 Serial port problems-img_4001-jpg   VF2 Serial port problems-img_3997-jpg   VF2 Serial port problems-img_3996-jpg
    VF2 Serial port problems-img_3995-jpg
    Member Machineit's Avatar
    Mar 2010
    Default Re: VF2 Serial port problems
    I have a spare if I can find. I can send it to you. PM me. I believe they are the same so you can just hook the RS232 cable to the one that is there.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
