Originally Posted by
HayreAss
Things aren't complicated at all.
I want my machine to be at the Z machine zero after every tool, and before the program starts.
So it is.
I edited a post, once, years ago, and it has done what I wanted it to do since that day.
My reseller made it do the same when they sent me new posts a while back.
Doesn't get easier or less complicated than that.
Sorry that how I do it offends your sensibilities.
I use a clearance plane, and a safety plane.
I like that, and it's my shop.
Unless someone can tell my why I would NOT want my head parked at machine zero at the beginning of a program, and after every tool, I'll just keep on keeping on.
I haven't seen a reason yet.
I did clean up the code though, it was simple enough.
I'm also OK with verifying the tip of my .026" ball endmills with a gage pin.
Been doing it since I got this 4th axis and started making these parts 6 or 7 years ago.
Made well over a hundred thousand of these parts so far.
Seems to work.
Unless I'm a brute, I'm not going to screw up that non cutting bit of the cutter any more than it's first plunge into titanium anyhow.
Hell, I only have to do it on rare occasion when my engraving seems to be off. (usually because the part diameter varied a little.)
Tenths make a difference on line width when you are only cutting a few thousandths deep with a tiny ball.
We sure have strayed far from "my machine was glitching" here! And I'm OK with that, I enjoy a debate.
You may not accept that it was glitching, but Haas, myself, and my local tech (who is actually sharp, not like a lot of techs) have all accepted the glitch.
