Listen to the Tech that is the correct way to do it, what ever you put in MDI will stay in MDI unless you change it, for some other speed, so all you have to do is select MDI and Press Start it's faster than what you were doing before, you can't use the FWD key to start the spindle that is only for the Tool changer
