You could TRY enclosing the search phrase in quotes, as in "N5005 G0".
I don't have a Haas, and don't know if this will work, but it should be easy for you to find out.
From time to time I need to restart the cnc in the middle of a program,... ( for example if my machine alarms out on low air pressure do to my air compressor that shuts down expectantly from time to time )
So my process is to go the the Haas controller and write down the line of code where the machine was at before it alarmed out.
My issue is that I have to do several searches on the control panel before it gets to the correct line.
So here is an example of the code where the machine quite
N5005 G0 Z0.2
So I tried doing a search for N5005 G0 and it brought me to other lines of code that didn't have that exact line of code. ( it did have the N5005, but the rest was not a match )
So what I end up doing is searching for just N5005 and I have to keep doing this search till it gets to the correct line.
Any suggestions on a quicker way to find the correct line of code?
Thanks,
Kent
If you turn on setting 36 you can restart on any line you choose to restart on, so if you have the Haas manual or look at one of their videos you will find how to do it, it's very simple once you know how, look for Haas Tip of the day videos they will have one for this
So, this parameter you will find in settings (Program Restart) 36 you change it from Off to On, you can turn it off when done with
Mactec54
U could also try to renumber Your program not to have more the same numbers of a block.
Yes, thats the feature I am using ( absolutely love that restart feature ) but the issue I am having is trying to search and advance to that point in the G-code where the machine stopped.He just needs to select the block where he wants to restart after setting Parameter 36 and the control will do the rest, it's very simple with his machine
In my example the line of code I am trying to advance to is " N5005 G0 Z0.2 "
My post processor creates multiple lines of code that has N5005 in it, so trying to find the correct one takes multiple search's.
If I do a search for N5005 it will bring me to the first one it finds, and then I need to do that search again to find the next one in the program... etc...etc...
I'm guessing my post processor restarts the line numbering after each separate operation in the program ( I am using Fusion 360 for creating my g-code )
Yes, I think your are spot on in your suggestion on the numbering... ( I am using Fusion 360 for creating my g-code, and I know I can turn numbering off, but I will have to do some digging to find out how to prevent duplicate numbering )U could also try to renumber Your program not to have more the same numbers of a block.
I like your suggestion, but when I went to try this I discovered that there isn't a quotation symbol on the haas keyboard.... ( I searched all of the keyboard and I see it has most of the common symbols by using the shift key, but can't seem to find the " symbol )
Paste Your postprocesor file here. Probably we could help with that.
I will have the same issue... this program has 240,988 lines of code in it, and I just checked and the line number "N5000" that was just above the one I'm trying to search for was repeated 35 times in this program. ( Just to clarify it repeated the line number, but not the rest of the line of code )
So I'm thinking my solution is to figure out why my cam software is repeating the numbering...
Here is just a small section of the code ( you will see that my cam software numbers by increasing each line number by 5 ) but the issue is that since this program has many different operations in it that it restarts the numbering for each operation... and that's whats giving me all of the duplicate line numbers.
N4970 X5.5842 Y-1.1723 Z-0.1158 F40.
N4975 X5.5834 Y-1.1739 Z-0.1151
N4980 X5.5827 Y-1.1753 Z-0.114
N4985 X5.5823 Y-1.1763 Z-0.1129
N4990 X5.5819 Y-1.177 Z-0.1116
N4995 X5.5817 Y-1.1775 Z-0.1101
N5000 Y-1.1777 Z-0.1081
N5005 G0 Z0.2
N5010 G1 X5.6668 Y-1.2148 F500.
N5015 Z-0.0469 F40.
N5020 X5.6669 Y-1.2149 Z-0.0486
N5025 X5.6675 Y-1.215 Z-0.0502
N5030 X5.6684 Y-1.2151 Z-0.0517
N5035 X5.6696 Y-1.2152 Z-0.0529
N5040 X5.671 Y-1.2151 Z-0.0539
N5045 X5.6726 Y-1.2147 Z-0.0545
N5050 X5.6741 Y-1.214 Z-0.0547
N5055 G3 X5.6733 Y-1.2144 Z-0.0569 I-0.0047 J0.0086
N5060 X5.6725 Y-1.2147 Z-0.059 I-0.0039 J0.009
N5065 X5.6717 Y-1.2149 Z-0.0611 I-0.0031 J0.0093
If you have the sequence number increase by 1... there would only be 7 repeats
If you refine your sequencing to be at toolchange AND at positioning moves, then the N blocks would be a very lot less...
....you could then refine further to have first 2 numbers for tool used, last 2 for positioning move count. Or variations on that concept.
it is repeating because there is maximal value set to 99999 so U had only ~2000 numbers aiailable.
Check if there won't be a problem with 6 digits on the block numbers.
i've changed Your file to make 6 digits and sequential block numbers so it wouldn't restart to often.
