Where you in MDI mode then you just type in the speed you want the spindle to run at. it must have S12000 in there for it to run at that speed which you should never have that speed in there
It could of run at the last speed the spindle was running at also, so make sure you are in MDI mode and have the speed that you want to run the spindle at set in the MDI
