HAAS VF7 SPINDLE OVERLOAD 200% HELP
Results 1 to 5 of 5
Thread: HAAS VF7 SPINDLE OVERLOAD 200% HELP
    Member Srgbjj's Avatar
    Apr 2022
    Default HAAS VF7 SPINDLE OVERLOAD 200% HELP
    Hey people! I’m in need of help with my VF7/50.
    It’s 2011 machine, we just got it out of auction. After installation I turned on the machine and wanted to run a warm up program, As soon as spindle start turning it shows me a 200% overload, with no tools in it. It spins freely by hand, I checked the encoder (it was very dirty and oily, but it works) I clean it and installed it back to the spindle. The encoder seems like giving a right measuring to the computer when I spin the spindle by hand. I checked the eye delta contractor, it looks good, no signs of any damage. Voltage going in and out, same voltage at all pins. All three phases reaches the spindle motor. So no meter what number of rpm’s up to 1000 It spins 10 rpm. If I program it to go 2000 rpm it spins 40-60 rpm.
    I’m struggling with it for a few days already, please help me with any advice or thoughts.
    Jul 2017
    Default Re: HAAS VF7 SPINDLE OVERLOAD 200% HELP
    Is the spindle driven by a belt? We had a little Mori that had most of the small V Belts come apart and it had trouble reaching speed and had no cutting power.
    Member Carlosh_obregon's Avatar
    Nov 2019
    Hi, did you solve the problem?
    I Have an older VF3 with the exact same issue
    Jan 2013
    england
    Quote Originally Posted by Srgbjj View Post
    I think you need to check the motor windings to ground and phase to phase. There could be a short, possibly moisture in the motor from storage. Disconnect the motor cables and check with a Megger ohm meter.
    If the motor checks out, suspect the drive transistors or other.
    Member mactec54's Avatar
    Jan 2005
    How are you powering the machine with a 3Ph supply or a RPC.
    Mactec54
