I have a 2001 Haas Mini Mill, new to me, bought with startup issues.
I have replaced the low voltage power supply with a Corsair 550w atx power supply and the Mill now has the correct input voltages.
The screen only shows a flashing cursor top centre.
If I start the machine while pressing PRGRM CONVRS, I get the following :-
HAAS 68030 MONITOR 05-MAY-99
SERIAL RATE IS 00009600
FLASH MEMORY FOUND: 1536 K : 00080000
BBU RAM FOUND 1024 K
68882 COPROCESSOR NOT FOUND
All 8 CPU boaard lights are on.
Any help to get the machine started would be appreciated, thank you.
