Originally Posted by
mactec54
Yes, this can be a common problem it is not the machine USB, but the drive you are using I use SanDisk drives that has a metal body, Ground it by touching a screw on the control with it, before you insert it, and you won't have any more problems, when taking a drive from a computer it can be in a charged state so when you insert it into the control, it will fault the drive, snip attached is the best I have found it has never failed for a few years now, just remember to ground it before you insert it, you can get them at Walmart.
