06 VF-2 side milling surface finish issues in one axis
Hey guys. I have been chasing this issue for a few months and I figure I should ask this group as I am sure someone has seen this before, The machine is an 06 VF-2D with a 7500rpm spindle. A little history. I bought the machine used almost a year ago from a broker in California. Looked great on the Facetime call and its super clean, so I pulled the trigger. Once it landed I got it placed, leveled, wired and ready to run. On the first cutting pass, I discovered the spindle was completely clapped out. .090 of vertical slop. Seller split a new spindle with me. I find out it was a tool room machine since new at Iscar. So I am sure this thing was run hard and put away wet every day of its existence. I bought a new spindle from HFO along with new drive belts and encoder belt. I get everything installed and now have the confidence the spindle is perfect. After a the first day of using the machine, I notice in direction changes in X, its a little clunky. Long story short, I go down the rabbit hole and replace the X and Y balls crews and couplers. Now I have a nice quiet tight machine that makes dimensionally perfect parts. The only thing I am left with is a funky side milling finish while cutting in the X direction. So I am constantly thinking about, what happened to damage the spindle originally and how could this potentially be a part of what I am experiencing now? Must have been a gnarly Z crash. I have asked some other machinists I know who have had years of experience making parts on Haas machines and everyone is scratching their heads. I am hoping someone here can look at this short video I have attached and have an answer. The less than perfect surface is from cutting in the X axis and the near perfect finish is the Y. This test is a contour moving around the part. Its being side milled with a G Shultz Alumigator 1/2 finisher in a hydraulic holder. I am wondering if this could be an X way/truck issue, or possibly even a drive/ motor issue? To recap, older machine leveled perfectly, not backlash at all in X and Y, bottom cutting and Y side milling are perfect, new balls screws and couplinge, thrust bearings, new spindle/draw bar assembly, belts, etc. I couldnt get the video to upload, so I hope these pics tell the story.
Re: 06 VF-2 side milling surface finish issues in one axis
maybe something in this thread. Some solid seniority level posts. The conclusion and some steps seem in line with some of your notes. https://tinyurl.com/2p87u58v
