Originally Posted by
Luigi101
So my question is this since no one else but Haas is making these 150in. linear guide X travel machines, what is the accuracy from the datum from one end to a drilled hole for instance at the end of that hundred and fifty inch travel? Can I hold true position tolerance without fear? Is repeatability going to be an issue? My own research puts accuracy .0001-.001. Not a good enough answer regardless of the load variables etc. So is there a good answer or do I go get a quote on a gantry or bridge mill? TIA
