Help please
Results 1 to 3 of 3
Thread: Help please
    Nov 2008
    england
    Default Help please
    I am really struggling to set up a Haas VF0E in setting the G54 correctly. Any help really appreciated
    Chris
    Jan 2005
    Default Re: Help please
    Quote Originally Posted by Fubar View Post
    Chris
    If you are new the easiest way to set G54 is, in offsets set the X0 and Y0 using a edge finder if you have a block then that would be the left side and the front of the stock, Z would be set ( 0 )
    Your Drawing in your cam program must match this X0 Y0 position also
    Then in tool offsets set your tool to the top of the part, and the same in your cam software also the top of the part is 0.0 where the machining starts
    Mactec54
    Nov 2008
    england
    Many Thanks Mactec 54,
    I have found my error in that I was inputting a negative value rather that a positive one !
Help please
Help please
Help please
