Need Help! Haas VF-1 1994 Spindle Encoder Wiring diagram
Results 1 to 4 of 4
Thread: Haas VF-1 1994 Spindle Encoder Wiring diagram
    Default Haas VF-1 1994 Spindle Encoder Wiring diagram
    Hi Everyone,
    Any advise on this type of encoder - Renco ENCODER RS25D-1000-3/8-5-LD0M1
    I have look online but unable to find any info on this type of encoder. I need to wire it up to new controller.
    Please check attached image of encoder.
    Regards
    Manni
    Attached Thumbnails Attached Thumbnails Haas VF-1 1994 Spindle Encoder Wiring diagram-img-20210219-wa0009-jpg
    Dec 2003
    Default Re: Haas VF-1 1994 Spindle Encoder Wiring diagram
    I have purchased Renco encoders for some years now, or at least before they were taken over by Heidenhain, Try contacting them via the Renco site, although since the take over they may not have kept records.
    Tt's worth a try!
    Thank you,
    here is what I found the closest match
    https://cdn.automationdirect.com/sta...-25_series.pdf
    Sep 2013
    going to post this up for later folks. I found several sources to match renco encoders on my Haas.
    Snippit from my post on that 'other' (PM) site below. Not your encoder, but the Co. can sub and match from your numbers. Fast and not too bad on prices .
    RENCO OEM (no longer avail) RHS21D-P1-2000-8mm-5-CS-LD-M1 P/N: 78994-008
    Replace w/ (We did not need.. Just providing list from Vendors I contacted who noted Renco subs).
    Dynapar part number HC202000/0024C Spec: https://ecatalog.dynapar.com/downloa...02918-0001.pdf
    Accu-coder : EPC PN: 260-N-B-14-H-2000-R-HV-1-S-SF-4-N (S – Denotes a special connector feature). This is a connector on a shortened cable. EPC is an 18” flying lead with no connector. (*put your own connector on.)
    Data Sheet Link: 260 Data Sheet (https://www.encoder.com/hubfs/produc....pdf?hsLang=en)
    Quantum Devices: QR145-05/05-2000-0-01-T5-01-00 Qty. 1- 194.12 ea.
    Quote Originally Posted by Munzi-cnc View Post
    Thank you,
