1992 Haas VF0
Results 1 to 4 of 4
Thread: 1992 Haas VF0
    Member Kubotaswapper's Avatar
    Oct 2019
    Default 1992 Haas VF0
    I recently picked up this little Tupperware VF0 from a friends shop that was moving.
    Serial number is in the 1800’s, very early machine.
    Everything works after a couple adjustments and cleaning.
    7k spindle, rigid tap etc.
    This is mainly for my personal use. I have run haas machines for about 20years.
    Ran my first real part and found issues with my “y” axis.
    I interpolated a 7.13in diameter hole in a piece of aluminum.
    “X” was dead on 7.13 but “Y” measure 7.148. Approx .018 large.
    I still need to do a backlash test, and recently found that this machine has belt driven ball screws.
    Could this be from stretch?
    Thank you
    Ken
    Member machinehop5's Avatar
    Aug 2009
    Default Re: 1992 Haas VF0
    ...possible incorrect Backlash setting?
    Oct 2019
    I will see if I can do backlash today. Hopefully it shows me something
    Ken
    Check thrust bearings, mechanical backlash with a dti, and runout on the screw, of course dont change any params without saving the original values, and go from there, good luck.
1992 Haas VF0
1992 Haas VF0
1992 Haas VF0
