Need Help! Haas High speed machining won't turn back on, after turning it off
Results 1 to 2 of 2
Thread: Haas High speed machining won't turn back on, after turning it off
    Apr 2017
    Netherlands
    Question Haas High speed machining won't turn back on, after turning it off
    I have a problem with my OM2a
    I (temporarily) disabled high speed machining.
    Because I wanted to see what the difference was in machining time.
    After I did my test, (and o boy what a difference.) I wanted to turn it back on.
    However I am unable to do this, when I try to change the parameter back from 0 to 1, I get a beep, but nothing happens.
    Other parameters a can change with no problem only high speed machining won’t turn back on.
    Hopefully it’s something stupid and it’s an easy fix.
    I have an OM2a Office Mill from 2007
    Jun 2018
    on my feet
    Default Re: Haas High speed machining won't turn back on, after turning it off
    I've never known of anyone ever turning it off but if it won't let you turn it back on then , you may need to re-enter your code or it's possible you'll need to get a new code from haas
    I agree , the difference of having hsm vs not is a night and day difference
