...in jog mode ?
Hello Friends,
Im working on Haas VF-2-I Machine.
According to Haas its possible to rotate spindle maximum of RPM 750 while door is open.
This feature essential for using edge finder.
But my machine cant rotate the spindle while door is open.
I search for setting number 292. Its not on the controller.
Appriciate someone can help me.
Thank in advanc.
...in jog mode ?
If your machine is newer then 2016 and has software newer the 100.17.000.XXXX then that setting no longer exists. Unfortunately you cannot run the spindle with the doors open.
I put a separate stick on the door switch of my old VF-2. It's inside the slot all the time and I can open the doors during work if necessary. Of course, I don't open them during milling, but sometimes this option is good.
