C axis unwinding on Haas 5X
Results 1 to 2 of 2
Thread: C axis unwinding on Haas 5X
    -9-9-9's Avatar
    May 2020
    Default C axis unwinding on Haas 5X
    Hi All,
    *I'm using PowerMill 2020 on a Haas 5 axis trunnion type of machine.
    *I'm wireframe swarf cutting the entire periphery of a part with a constant
    5 degree draft.
    *In the simulation it all looks good.
    When executing on the machine*it leads in,machines around until reaching the point of passing C zero
    where it rotates C360.0 back to the same position it was at , then continues the path and leads off of the part.
    During this repostioning it does not lift z or reorient the A/C axis positions to prevent gouging.
    Is this a setting in the post , the PM software, or a machine setting?
    Attached Thumbnails Attached Thumbnails C axis unwinding on Haas 5X-img_1014-jpg   C axis unwinding on Haas 5X-img_1015-jpg
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: C axis unwinding on Haas 5X
    It would be either a post or programmer error... I'd lean toward a programming error.
    .... long time since using PM, but look for a "Retract between Cuts" or possibly a "Keep tool down" setting
