AIR PRESSURE SENSOR
Results 1 to 3 of 3
Thread: AIR PRESSURE SENSOR
    Default AIR PRESSURE SENSOR
    we have some troubleshooting with our vertical center VF3 SS YT.
    we need help with the reference of the air pressure sensor, and where we can buy it.
    thank you for help.
    Attached Thumbnails Attached Thumbnails AIR PRESSURE SENSOR-capteur-de-pression-schema-jpg   AIR PRESSURE SENSOR-capteur-de-pression-jpg
    Dec 2013
    Default Re: AIR PRESSURE SENSOR
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    Looks like a standard device, have you checked out any local pneumatic vendors?
    Countryguy1225
    Guest
    If there is any PN, model, or imprinted info on it... pass along. As AtM notes.. they are pretty standard devices. Haas Parts is usually ok on these type of small items though...
    Hi JD! Nice to see the title on your IF here.
AIR PRESSURE SENSOR
AIR PRESSURE SENSOR
