encoder
Results 1 to 3 of 3
Thread: encoder
    Nov 2009
    Default encoder
    Hello all,
    We are getting a 185 alarm when hooking up the HRT310 rotary. It is a brush type rotary going thru a Haas conversion box hooking to a 2008 VF4.Disconnecting the cable at the rotary and checking continuity to the plug ends the cable seems to be ok. Is it possible to test an encoder on a Haas rotary?
    Member Machineit's Avatar
    Mar 2010
    Default Re: encoder
    Quote Originally Posted by murphdog View Post
    Hello all,
    Have you selected the proper unit in the settings?
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Nov 2009
    Default Re: encoder
    Quote Originally Posted by Machineit View Post
    Yes. We are using the plain 350 rotary setting (brush type) because we are running this thru the Haas converter box that allows us to use a brush type rotary in a "brushless" machine. This is the same setting we have used before.
encoder
encoder
encoder
