Need Help! Haas VF1250 Problem fffffff on on my screen
Results 1 to 4 of 4
Thread: Haas VF1250 Problem fffffff on on my screen
    Member FredHaasVF3's Avatar
    Mar 2020
    Default Haas VF1250 Problem fffffff on on my screen
    My Haas VF1250 gets fffffff on on my screen.
    when it fills up, the bank falls into disruption
    how can i fix this
    Attached Thumbnails Attached Thumbnails Haas VF1250  Problem  fffffff on on my screen-img_20190828_123541-jpg
    Jul 2014
    Default Re: Haas VF1250 Problem fffffff on on my screen
    Your processor board is going.
    Countryguy1225
    Guest
    Same issue I had. .27 cent C40 capacitor in the -232 comms chip. (Or something in chip itself). Find post by me on the other site. P
    R a tic l. Mach in sts. Same handle. From 2018. Details all. Same for a post in the last month with some help to a member in how I did the repair.
    Phone typing. Pm on other site lfor more details.
    No clue on CncZome anymore as I am forced to use industry arena logins ? Posts don’t show up at times either?
    Cg
    Jun 2008
    Netherlands
    Quote Originally Posted by AdminCrew View Post
    Cg
    Can you give the details to repair this problem.
    HN
    Sep 2013
    yup... Most of the info is in here.
    https://tinyurl.com/wcmbpxc
    C41 if I recall. The -12 is 'derived' from a special RS232 capable IC. (all the tech goo is in my thread). And the small capacitor is part of the required components to 'make' -12VDc for RS232 internally to/from the serial connected areas like keyboard comms ( I think.. it's been a few years now). Anywho- That caps begins to fail and you get the ffffff or ggggg stuff. it's an easy fix if you can run a small solder pencil. My post goes into the special solder tools I used. it's like $40 for the iron Don't think your going to grab the big Weller iron you had since the 90's and do it typically.
