Need Help! 2nd Week using HAAS - G52 Problem
Results 1 to 3 of 3
Thread: 2nd Week using HAAS - G52 Problem
    Member BlaznLow's Avatar
    Jan 2020
    Default 2nd Week using HAAS - G52 Problem
    Hey everyone,
    I am new to the HAAS world, approx 2 weeks.
    Prior to this, I have been running FANUC for 8 years.
    I am running a part where I am using a helix to create a 2"DIA x 1.5" deep hole.
    On the FANUC, to make sure I am not going to deep, on the work offset page, I could throw in .050" into G52. It would raise my program that amount, I could measure my depth and adjust accordingly.
    On the HAAS, I had centre drill and drilled my hole. I reset my program. I then put .050 into my work offset page in G52. I read the first part of my program, I go to edit, skip down to my endmill. However, when i go to edit, it erase my .050 from G52.
    Why does it keep erasing my .050 from G52? It never did this on a FANUC control.
    Thank you.
    Moderator wms's Avatar
    Mar 2003
    Default Re: 2nd Week using HAAS - G52 Problem
    You can just add the .050 to your work offset Z value..
    So if you are using say G54, add .05 to the z value in the work offset table.
    Jan 2020
    Quote Originally Posted by wms View Post
    Which is what I did. But still curious as to why G52 cancels itself
    Member Edl44251's Avatar
    Jan 2020
    You have to change a setting from yasnac to fanuc Haas will tell you setting # for your machine.
