Haas VF help
Results 1 to 6 of 6
Thread: Haas VF help
    Mar 2013
    Default Haas VF help
    Vintage 1998 HAAS
    When my tool holder grabs a tool and the spindle starts, there is a delay when set at any speeds above 2000 rpm, if I am doing an aggressive adaptive clearing I have to FEED HOLD right above work and wait about 5 sec for vfd to ramp up, if I dont it plows in, at low speed and then eventually alarms out shutting down. Anyone know why it would delay before going full rpm? I noticed this after losing my original HAAS .post file.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Haas VF help
    check Parameter 209 bit 31 (SPNDLE NOWAIT)
    https://www.haascnc.com/content/dam/...ual---2002.pdf
    PAGE 278-279
    Mar 2013
    Thanks for the response, I cannot find that parameter even though its in my book, I am on the 209 par page also???
    Aug 2009
    YW.
    Did you use the? ............."The left and right cursor arrows are used to select the function being changed. All values
    are 0 or 1 only."
    DJ
    Mar 2013
    I know how to change it, just cannot find that parameter on my list under 209
    Mar 2013
    Quote Originally Posted by repauli1 View Post
    A work around I put a G4 P2500 right after the G54 move (Dwell 2500ms)
Haas VF help
Haas VF help
