Need Help! WHAT IS THIS?!?!?
Results 1 to 18 of 18
Thread: WHAT IS THIS?!?!?
    Jan 2012
    Default WHAT IS THIS?!?!?
    I purchased a 2010 TM-2 with 10 ATC.
    Everything is working great, but there is this bracket (Pictured).
    I can't figure out where it bolts to or what it's for.
    Anyone?!?!?
    WHAT IS THIS?!?!?-20200108_215310-jpg
    WHAT IS THIS?!?!?-20200109_081517-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: WHAT IS THIS?!?!?
    TheThing with gray looking stuff all over it on some brown back ground and a black triangle in lower right hand bottom corner and some robot forgot to deburr the black hole looking dot?
    on the machine.
    Dec 2013
    I don't remember anything like that on my TM-2. Looks like a shipping bracket, door latch maybe?
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    Tool or Die works...had something to do with I'll bet for sure.
    Jun 2018
    on my feet
    I don't remember seeing anything like it , but air line holder is the first thing I thought
    Aug 2009
    Who is this ?
  7. #7
    Aug 2009
    Watts on 2nd
  8. #8
    Aug 2009
    please send DNA code...via zipfile
  9. #9
    Member 2ferrous's Avatar
    Jul 2010
    I have something like that on my VF0E.
    It was for hanging the washdown hose on the back of the machine.
    Yours is a bit smaller so I'd say it's for hanging your air line blow gun on.
    Where is it bolted to the machine?
    Dyna Mechtronics DM4400, HAAS VF-0E, HAAS Mini Mill
  10. #10
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Conundrum68 View Post
    Anyone?!?!?WHAT IS THIS?!?!?-20200108_215310-jpg
    Check to see if you can mount it on the side front of the machine for your Vice Handle
    Does your machine have a full enclosure?? most this age did not
    Mactec54
  11. #11
    Jan 2012
    Quote Originally Posted by 2ferrous View Post
    That's the thing, it wasn't bolted to the machine. I assumed it was to hang an air line or T-Slot cleaner, but can't find where the hell it could mount. Don't really want to drill a hole.
  12. #12
    Jan 2012
    Machine is not full enclosure.
    The way it is constructed tells me it should be mounted to the right side of the machine, but there is no mounting hole there.Does HAAS typically suggest the owner drill holes for accessory items like this?
  13. #13
    Jan 2005
    No normally all there accessories all bolt or screwed in place some are just clipped on, it may not be for your machine Give Haas a call they may know, 2010 had a chip Guard for around the table it may have attached to the right side of the chip guard
    Mactec54
  14. #14
    Dec 2003
    Anyone?!?!?
    Every job there are parts left over.
    Sweep them around 'til they 'disappear'!.
    Jan 2012
    Ok looks like it bolts to the side of the control panel.
    The air gun sort of hangs there, but I suspect the remote safety pushbutton thing is supposed to hang there. The guy I bought it from "altered" the thing and added a dead-man switch. I don't know what it us supposed to look like.
    WHAT IS THIS?!?!?-20200109_110930-jpg
    WHAT IS THIS?!?!?-20200109_110937-jpg
    WHAT IS THIS?!?!?-20200109_181250-jpg
  16. #16
    Aug 2009
    Its for hanging the Hand Held MPG?
    https://i.ebayimg.com/images/g/KNkAA...eD/s-l1600.jpg
  17. #17
    Jan 2005
    Quote Originally Posted by machinehop5 View Post
    That's the safety switch that these machines required
    Mactec54
  18. #18
    Jul 2010
    Yeah, now I remember.
    There was something just like that on my TL-1.
    Sold it a year and a half ago though.
    The bracket bolted to the side of the control panel and that irritating safety switch hung off of it.
    Timothy
WHAT IS THIS?!?!?
WHAT IS THIS?!?!?
