Problem VF3 power failure alarm
Results 1 to 4 of 4
Thread: VF3 power failure alarm
    Jan 2013
    Default VF3 power failure alarm
    I am getting a power failure alarm a few times a day on my 1994 VF3. The control freezes up and I have to cycle the power to clear. No alarm code is given, just the words 'power failure alarm' as you can see in the image attached. Has anyone had a similar problem and found the source of the problem?
    Jordan.
    Attached Thumbnails Attached Thumbnails VF3 power failure alarm-20191121_105247-jpg
    Member djr76's Avatar
    Nov 2007
    automation alley
    Default Re: VF3 power failure alarm
    I would google Haas Australia and call the closet hfo near you and talk with tech support.
    Member RnjPrecisionLLC's Avatar
    Feb 2021
    Quote Originally Posted by agsy103 View Post
    Jordan.
    Did you end up fixing this if so what was the problem?
    Ron
    Jan 2013
    Quote Originally Posted by RnjPrecisionLLC View Post
    Ron
    No, it just went away. It usually only happens on hot days. I believe there are some diodes on the powerboard that wear out.
