I own a haas tm1 2005 using fusion 360 cad/cam. I have stumbled across the issue of my usb not displaying files on my machine, even though the files are readable from the usb on my laptop. At first i thought it was the usb but im able to get some gcode files to display. I narrowed it down to parallel toolpaths with less than .030 stepover are not visible to my machine. I thought it was file size but my adaptive paths are bigger than my desired parallel file. Is there a setting or parameter that is keeping the machine from reading the fine stepover parallel files.
Assuming you have floppy disk to usb modified machine.
you'll find this if there are too many files on the usb stick larger than the capacity of the machine.
create some folders to dump files into and only leave the wanted prg on the root of the usb
