Need some advice on Vise Clamps
Results 1 to 5 of 5
Thread: Need some advice on Vise Clamps
    May 2013
    Default Need some advice on Vise Clamps
    I purchased a couple of vises for my Haas, and they didn't come with clamps, and they don't have bolt slots on the side.
    I'm on a tight budget at the moment.... so I didn't buy the most expensive vise... but it's still an upgrade for me.
    So I was forced to machine up a side clamp.
    My plan is to put 2 of these on each side of the clamp.
    I machined these out of Aluminum.... ( I know I should have used hardened steel, but I don't have access to this at the moment, and to be totally honest I haven't done any machining of steel.... I only work with Aluminum at this point )
    The sample clamp I made is plenty beefy in my opinion.... but I would like a second, or third opinion.
    Attached are some photos of the aluminum clamp.
    ( I forgot to include the thickness of the stock.... It's 1 1/4" thick. )
    Thanks,
    Kent
    Attached Thumbnails Attached Thumbnails Need some advice on Vise Clamps-20191011_182527-jpg   Need some advice on Vise Clamps-vice-clamp-jpg
    Mar 2017
    Default Re: Need some advice on Vise Clamps
    That looks fabulous to me. If you only machine aluminum you may never need a steel set. Just make sure to keep them tight.
    What Haas do you have? What is the motor HP?
    May 2013
    Thanks Bob...
    I have a Haas Super Mini Mill
    15HP
    10,000 rpm spindle
    Thanks again Bob...
    Kent
    Quote Originally Posted by maxspongebob View Post
    Member Machineit's Avatar
    Mar 2010
    Looks ok, but prepare for the future and get a set like this to have handy.
    https://www.ebay.com/itm/58Pc-1-2-Sl...3d517b2f065d5e
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by kentdesautel13 View Post
    Thanks Bob...
    15HP
    10,000 rpm spindle
    Thanks again Bob...
    Kent
    Now that you have them made, make some out of 1018 steel or 4140 just the same, as the aluminum mounting on to the table like this will react and over time the aluminum and the table will be damaged
    Use a 1/2 SHCS with the head in a pocket milled into the top of the clamp, that way you don't have to worry about the nut up o top of your clamp block
    Mactec54
