You would need pins 2 and 3 swapped. I would also caution heavily against using switches. Seen PLENTY of blown comm ports from those. USB to Serial adapters are like $10 now days, just set up individual comm ports for each machine. Much safer.
Hi all,
I am trying to set up a cable to send programs to our 2005 Haas VF-2. It'll be a 25 pin male on both ends. My question is, should they be pinned the same on both ends? I'm fine using software handshakes for now, so I will not be putting jumped pins in. I've been looking around all day and haven't come up with any info on going 25 male to 25 male. The manual says...
Female
Pin 1 - Ground
Pin 2 - Red
Pin 3 - Black
Pin 7 - Green
Male
Pin 1 - Ground
Pin 2 - Black
Pin 3 - Red
Pin 7 - Green
However this is not a configuration I'd be able to use, as the switch has a female out.
Thanks for any help
