No idea I have a year old TM1P with most options and the 4th axis and single phase is fine.
Hello all,
I am looking at the mini mill and it says at the website that it operates on single- or three-phase power (three-phase power is required for some options). My question is what are the options that require three phase?
If I remember right, its the high-flow coolant pump.
I believe you are right the super’s spindle has the higher rpm requiring 3 phase, I have the high pressure coolant it’s single phase.
In my understanding, some type of spindles or coolant pumps needs three phase powers, to clarify this, you must contact supplier. In case of 1 phase requirement, there are limited choices.
