Silly question is it turned on in your parameters?
Dear forum members
Regarding Hass ST30
I had memory lost after my battery died , so i took the Hass recovery USB and restored my machine and everything was restored except my C axis - showing me "C axis drive alarm" .
I double checked my parameters with original machine parameters and its they are the same , tried to replace C axis drive and still kept showing the alarm.
Before the battery died C axis was fully operational.
Did anyone had this problem before?
Much appreaciation!
First of all thanks for replying !
Well i did install all parameters via "Hass USB" ( the original that I recieved with the machine) and verify also on the machine that all parameters are as they should be .
Is it possible that it is special option that only hass person can open ?
I think it's an option parameter on your machine
If you check the paperwork that came with your machine there should be a page showing options that can be enabled and the relevant codes to turn them on
regards. friend I have the same problem of the loss of parameters after the battery discharge. You can give me the parameters of the machine. send them to the email cesarmezar1@hotmail.com
I appreciate your help.
Thank you
Hi friends!
I have a problem... I'm missing parameters after replacing the battery on cnc hass st 30. Can someone send me to boban987@gmail.com
I would be extremely grateful
