Spindle failed after only 229 cutting hrs? - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 32 of 32
Thread: Spindle failed after only 229 cutting hrs?
  1. #25
    Gold Member LeeWay's Avatar
    Jun 2004
    Default Re: Spindle failed after only 229 cutting hrs?
    So did they charge a core charge for the old spindle?
    Do you have to ship it back?
    If not, you have a golden chance to see what went wrong and possibly rebuild it yourself or someone locally and have spare.
    Lee
  2. #26
    Jan 2005
    Quote Originally Posted by LeeWay View Post
    They change the whole spindle, you can not do an in place core change, with a precision built spindle, they are assembled in a clean room any contamination can destroy a spindle like this
    Hass would charge you a core charge if you keep it
    Mactec54
  3. #27
    Jun 2004
    That is about what I gathered from reading about spindles and repairs. Thanks for the confirmation.
    Lee
  4. #28
    Dec 2004
    I would call C&M spindle in Oregon .. there great to deal with and way cheaper than buying a new spindle ,, they did a friends fadal for $2,200 a couple years ago ,, i`m thinking a Haas should be around that price.
  5. #29
    Sep 2007
    Well the new spindle was installed a week ago. I had a chance to make several parts this week with it. I have no doubt now that the original spindle wasn’t right from day one. But since I had nothing to compare it two I didn’t recognize the issue. The new spindle is way, way quieter than the old one ever was. Not by a little but by a lot. Also the new spindle runs at a much lower spindle load when free spinning with just a tool in the holder. With the old one the spindle load ran about 12 to 14% at 4000 rpm. The new spindle runs about 4 or 5% at 4000. Also with the old spindle if I ran a very long cycle (40 mins or so) the tool would get stuck. Sometimes it wouldn’t come out without a very large bang at the tool changer. I had actually posted on here asking what to do about that because it was rocking the tool changer pretty hard and a few times the machine faulted out because it couldn’t pull the tool out. I have top quality holders so I knew it wasn’t those. Now I think it was because the spindle was heating up with use. Anyway you all were right I should have just changed it myself. The tech that came to do the job didn’t use a single tool that I didn’t already have in my shop. No special alignment procedure after the install. Just unbolt the old one and bolt in the new one. Total cost was $5900. But what really sucks is that Haas was no help at all. I couldn’t even get them to listen to me. By that I mean they wouldn’t stand behind a spindle that failed after only 229 cutting hours. Nearly $6000 for 229 hours of use is pretty miserable performance.
    Attached Thumbnails Attached Thumbnails Spindle failed after only 229 cutting hrs?-96077026-50b2-4153-8af1-61cd7dd82df2-jpg
    2008 Haas TM-1, 2009 TL-1
  6. #30
    Sep 2007
    Break in program running.
    Attached Thumbnails Attached Thumbnails Spindle failed after only 229 cutting hrs?-a4062d93-cbd0-4a0a-a93f-2fb59db29b6a-jpg   Spindle failed after only 229 cutting hrs?-07e40a55-3807-46c7-9d6e-c85581abd261-jpg
  7. #31
    Dec 2004
    is this the 2008 tm-1 you have at the bottom of all your posts? did you check with C&M spindle ?
  8. #32
    Member fostereast's Avatar
    Mar 2019
    Belts too tight?
