I'm guessing nobody has seen anything like this before?
I purchased a 98 Haas VF-2 earlier this year and have been slowly cleaning and fixing minor issues getting it ready to run. Machine has been down powered for a while. Yesterday I put the way lube system back together and powered up. I get the normal beep but doesn't boot just says "0303FFFC FFC7". Googled this and found only 1 person with this problem with no solution. Further investigating found vector drive green fault light is on. Output voltage is 338vdc. Also noticed clicking relay I think from vector drive a few seconds after power up. Also found halt lights on MOCON and processor board. Removed all cables from MOCON board with same result. Removed data and address cables from processor and I get the all J's screen that I have been getting every once in a while during power up. Pressing program button during powerup shows 0k bbu ram and no coprocessor. Not sure what that means. Take a look at the screen pics. Any help is appreciated. Thanks.
- Need Help!- Haas 2010 TM2P suddenly wont boot up!
- 164 Drive fault. A Axis. chasing thie bug on used machine week now. ABrk? MoCon?
- Haas Closed Loop Vector Drive 40/30 HP ...fault ??
- Need Help!- Project! Haas Vector Drive replacement, MOCON board / Brushless Servo Amp interface
- Need Help!- vf4 wont boot up, system fault
Removed MOCON and video board to measure battery voltage. Battery was at 3.08 VDC. Was actually hoping battery had just died and board was fine but looking like not. I read on another thread someone fixing a similar issue by replacing capacitor C40 on processor board and caps in power supply. The power supply voltages are good. With all boards installed voltages were 4.98, 12.02, -12.07. With MOCON and video board removed 5.11, -11.69, 11.64. Not sure why 12/-12 were low with boards removed. AC VRMS were a few millivolts so pretty clean. Processor board is a 34-3090A although sticker inside machine says it came with a 32-3090A so I'm guessing the processor has been replaced before? What are the odds the board could be repaired?
Have you had a resolution to the processor issue? If not, get in touch with me so I can have your board repaired. eric@wisrepairs.com
We can repair the processor for you. Worldwide Industrial Solutions eric@wisrepairs.com / 855-437-3497 x105
Eric Knapp
Worldwide Industrial Solutions in Dahlonega, GA. They repair these all the time.
