Wierd Alarm 179 - 1994 Haas VF2
Results 1 to 4 of 4
Thread: Wierd Alarm 179 - 1994 Haas VF2
    *Registered User* willby24's Avatar
    Aug 2018
    Default Wierd Alarm 179 - 1994 Haas VF2
    Can't seem to narrow this one down. I started the machine up after sitting for 4 days, and during the power up/zero procedure the machine stopped and gave me a 179 alarm. No other alarms present. I can reset the alarm and finish zeroing the machine, run the spindle(very briefly at low rpm), and jog the table around. However I can not release the tool in the spindle, orient the spindle, or perform a tool change. I can also not shift it into high gear. I took the top cover off and found that the pump wasn't pumping oil. So I added oil in case it was low, but still encountered the same problem. The coupler between the pump and motor is in good shape. I can spin the pump with the motor off with my finger and it spins easily and I can see fluid moving. The pressure sensor looks pretty new. We've only had this machine for a little over a year.
    I figured the motor was bad and the sensor was just kicking on from not seeing pressure, so I just picked up a new one(found a part number on this site of a motor that will work), plugged it in to make sure it works and it wont spin either.
    From what I read, the pump shouldn't start until I turn the spindle on, correct? So how am I getting this alarm on the power up sequence when the spindle isn't turning?
    Any ideas what else to look for? I'm currently tracing the wiring to see if the motor is getting power from the back of the machine. I'm hoping its not a board in the rear. Other then that, I'm out of ideas. I'd really love to not have to call my local HFO.
    Thanks for the help,
    Will
    Feb 2012
    Default Re: Wierd Alarm 179 - 1994 Haas VF2
    Have you checked your relays and fuses?
    May 2016
    United Kingdom
    Behind the spindle there is a blue pneumatic valve that is probably not activating
    This enables the gear change from Hi to Lo gear (hence you get an alarm )
    On power up/ restart the machine goes into low gear to reference the spindle and then rotates for position of tool in line with the carousel for tool change
    Apr 2012
    Alarm 179 LOW GEARBOX OIL PRESSURE
    The oil level is low. Fix the leaks and refill with oil.
    There is a clog in the oil-pump inlet screen. Clean the oil-pump inlet screen.
    There is a problem with the oil flow sensor or pressure switch. Troubleshoot the oil flow sensor or pressure switch.
    The oil-pump motor does not receive power. Troubleshoot the oil-pump motor.
    There is a problem with the oil-pump motor gears or coupler. Inspect the gears or coupler.
