Your 4th axis drive should be a brush and brushless drive. See the door label and it may show you. Of course someone could have changed it. Mine is a 4015H-G.
Before you can just hook up the drive, you need to setup the parameters too. I can post if you need them. Each drive, HRT210, HA5C etc. are all different settings.
Don't swap into the 4th axis to test, as it can damage the brushless drives. You could use the 4th axis drive for a X Y or Z position but not the other way around.
Mike
