I just measured my TM2, it's about 106 to the top of the flex conduit going to the spindle. The spindle drive resistor housing (removable) is about 7 ft 4 inches. The machine frame is about 3 inches off the floor on the leveling pads. You might be able to just slide it under a 7 ft door. I think you might need a bit more room above the flex conduit, but it is pretty flexible so you maybe have a couple of inches there.
