Need Help! Haas VF2 way/spindle oil?
Results 1 to 12 of 12
Thread: Haas VF2 way/spindle oil?
    Jun 2008
    Default Haas VF2 way/spindle oil?
    I recently purchased a 98 Haas VF2 that has been very neglected. I removed the way covers and found large amounts of chips and rust. I found that the x axis was not getting way oil due to clogged metering valves. The linear slide has rust and was extremely dirty. I am trying to clean the metering valves due to them being $15 a piece but I have read that it may impossible to clean them. I would like to keep this from happening again so I am going to purchase the correct oil for the mechanical oiler. The oiler says to use Vactra #2 but the Haas website says to use Mobil SHC 625. From what I can see the mechanical oiler oils the ways and the spindle which seemed odd to oil the spindle with way oil. The oil tank has a large amount of sludge. The Haas website says to use Mobil SHC 625 due to Vactra causing sludge in the tank which I have. I know I'm gonna get blasted for asking but can I use some ISO 46 hydraulic oil which is the same viscosity and I have tons of it. The Haas website says the alternative is 5w-20 engine oil. I would think ISO 46 hydraulic oil would be a better choice. Keep in mind this is an old ragged out machine with bad liner slides and 17,000 hours. Check out the pictures of what I am dealing with. Thanks. I don't have a picture of the x axis but I will post later, it will make you cringe.
    Haas VF2 way/spindle oil?-20180218_113613-jpg
    Haas VF2 way/spindle oil?-20180306_213318-jpg
    Haas VF2 way/spindle oil?-20180308_203657-jpg
    Haas VF2 way/spindle oil?-20180308_203702-jpg
    Jun 2008
    Default Re: Haas VF2 way/spindle oil?
    Here is what the Haas website says.
    Haas VF2 way/spindle oil?-capture-jpg
    Apr 2014
    This is the first I’ve heard of this I thought vactra2 didn’t have wax in it and was good to go because it wouldn’t congeal?
    Jun 2008
    Quote Originally Posted by ianagos View Post
    When I get back to the shop I will take a picture of the sludge. I don't want this to happen again and clog up the metering valves. They are kind of expensive, hard to replace, and not obvious when they clog up which could cause damage to much more expensive parts.
    Apr 2014
    Quote Originally Posted by dwilley View Post
    My fadal recommends vactra 2 because it won’t gum up. Strange I need to check and replace the metering valves.
    Member Machineit's Avatar
    Mar 2010
    What appears as sludge is probably old coolant oils.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
  7. #7
    Activation process fishyfishy's Avatar
    Jan 2019
    I just bought a 1999 VF-2. I'm a little further along in my cleaning and have come across several problems too. Let me know if you need any pics or anything else.
  8. #8
    Mar 2010
    Quote Originally Posted by fishyfishy View Post
    Year old post!
  9. #9
    Member mactec54's Avatar
    Jan 2005
    I have some of the same year machines and have no sludge and use Vactra #2, the recommended oil by Haas, there is more going on than the oil, someone was probably mixing the oil with non machine quality oil
    Mactec54
  10. #10
    Jan 2005
    Quote Originally Posted by Machineit View Post
    Year old post!
    Yes it is surprising how often these post come up, but some are worth reviving because there quite often is new content that can be added
    Mactec54
  11. #11
    Mar 2010
    I agree, as I have two machines over 20 years old and no problems. I would stick with Vactra #2.
  12. #12
    Jan 2019
    DOH!!! I saw 3/20 and got excited that I might be able to help for once. :-) Thanks for pointing that out!
