So one of our machines (2006 VF-2SS) is alarming "121 Low lube or low pressure". Plenty of oil. Also our drip container is filling fast with oil.
It seems like a slam dunk symptom of a broken way oil line. We'll start searching for the leak tomorrow.
Any recommendations about a start point to search? X way covers?
Probably under the "Y" covers.
the "X" leaks probably would end up in the coolant tank not in the drip tube. Good to clean under there once a year anyway.
Update: we called in the HFO. They replaced all the way oil lines. Did a good job. They also replaced the wipers (unrelated to the leak obviously). We're up and running.
