Good day for all, change the spindle encoder of a vf3 for installation failure all right to put into operation for belt adjustment and subsequent heating rotation for 30 seconds and be alarmed by marking failure in the pulse counter check parameters and connections all right and in the installation followed the recommended procedure; the previous one marked the same alarm by just touching the spindle (it did not turn) so they decided to change it. Someone who can help me with this. I appreciate your attention and help
My, are you using google translate, this is a bit hard to follow. Depending what you changed from/to, your counts per rev may be different than the Z counts which may be double.
am sorry my english is poor i need more practice for comunicate
i´m working on taking a course to improve this
in effect used the translator for long texts
i hope i can give myself to understand without a translator
my problem: at changed the spindle encoder new and tested rotated a few seconds and is alarmed again
i update the parameters values but alarmed continues
which may be failing by you attention and helps thanks
What year is the machine? My 96 vf2 complained about this until I set the count per z to 8000 and the counts per rev to 4000. It because of the 2:1 gear belt ratio.
dear erikfriesen
it´s year is 2008, i already made some adjustement without result. what parameters did you move?
with the number or name maybe it is a good guide
anyway i will check the cable, the alarm indicates that it may be damaged and can be the cause of the failure even though I had already reviewed it
you speak spanish?
well I will review those parameters that should not be different in the years that I have worked with the haas machines do not a change much keeps a line improving with the passage of time and have more aplications.
checked cable and connections on pcb all good i still think that one parameter this wrong
tomorrow i review these parameters and see what happens
i tell you the result
There is a count difference if you are changing from old to new style, 8000 vs 8192 for the new.
Hay una diferencia entre el Nuevo y Viejo, El neuvo tipo tiene una cuenta por revolution de 8192, y es posible que es su problema. El papel que viene con El nuevo encoder se dira a ud.
Dear erikfriesen,
solved problem are 8096
very grateful for your support
i had reviewed everything and imagined it was a parameter
gracias estimado en efecto el que viene con la maquina de fabrica es 8000 y para el nuevo es 8096 fue de gran ayuda tus comentarios investigue el encoder y me faltaba un parametro por definir al cambiarlo se termino el problema.
