The controller will make no difference, as the code is all the same. Inside the cabinet there should be a build sticker or paper that will show if it is wired for the 4th, plus there will be an extra drive. Just check to see if it is pre-wired for a 4th axis and you will be able to fully control the rotary table or whatever you hook to it.
