Originally Posted by
D.D.Machine
I`m working on one to do just that wash down the floor in a vf4ss.. I`m tired of all the alum chips building up all the time ,,,, I picked up a well pump to put next to the back of the sump and plan to use 11/2" pipe with holes in it. I have hooked up a momentary foot switch , I don`t want wet hands on the power switch, I want lots of flow with low pressure ,,, the pickup for the pump has about .090 holes in it and the pipe will get .125 holes so it should be self cleaning ... I plan to start with 1/8" holes about every 2" along the pipe then drill them out bigger tell I get lots of flow with low pressure . I can test it in the driveway with a trash can full of water before I put in the machine,,,
you can build one out of home depot for about $300
