The standard pump runs on 240V and the circuit that supplies it can carry up to 10 amps. There is a breaker inside the cabinet labelled Coolant or something like that so you can check this. You could plug in any pump that runs off 240V or you could get a step down transformer and get a 120V pump.Originally Posted by engine tech art
Regarding the programmable coolant nozzle you might be out of luck. Check the Haas website, Hasscnc.com to see if it can be retrofitted. I suspect the answer is no and even if it can the cost will be high.
I find with a high volume pump you can run several nozzles spanning all your different tool lengths and get almost the same effect as a programmable nozzle.
